Growing A Shape Vertically
COW Forums : Apple Motion
Steve Crow
on Jul 12, 2009 at 9:35:52 pm
This isn't a question, it's an answer - to my own question. I found the solution just now and it was staring me in the face the whole time. The issue was how to make a shape, like a vertical bar grow higher or lower.
The answer is:
1. Set the Y value of the anchor point so that it is at the bottom of the shape instead of its default location in the center.
2. Next, under "Scale" animate the Y value up and down as needed to grow and shrink the shape vertically.
You wouldn't believe the ugly workarounds I was using to create this effect.
Ariane Fisher
Re: Growing A Shape Vertically
on Jul 13, 2009 at 3:06:44 pm
You can also create the rectangle at the final size you want, and then animate a crop or rectangle mask to reveal it.
