How to manually select the Match Move source?
COW Forums : Apple Motion
Paul Lumsden
on Jul 10, 2009 at 3:37:49 pm
Heya,
I'm doing what I thought would be a very simple operation. I'm trying to match move a text to background video. I've done this with importing the text from photoshop, no problem.
But now I'm trying to match move using the text tool in Motion as the top layer, and the background video as the source. When i select the Match Move behavior for the text, it doesn't select the background layer as the source, and the source window in the HUD says 'none'. How can I select the source for the Match Move manually?
Cheers!
Stephen Smith
Re: How to manually select the Match Move source?
on Jul 10, 2009 at 3:50:17 pm
The source layer always defaults to the layer/group below the object with the Match Move behavior applied. To fix change it just move the image you want as your source into the source well from the Project pane or timeline. Hope this helps.
Stephen Smith
Lone Peak Productions
Check out the TV Show Open I did.
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Paul Lumsden
on Jul 10, 2009 at 4:49:00 pm
Ah, the old drag and drop!
Nice one, that's sorted it. Cheers fella!
Stephen Smith
on Jul 10, 2009 at 4:54:31 pm
Awesome!
Stephen Smith
