Apple Motion Video Output
COW Forums : Apple Motion
Matthew Riggieri
on Jul 9, 2009 at 7:07:13 pm
Hello All
I am having a weird issue when using the video output in Motion 3.0.2. On a dual-dual core 3Ghz with BlackMagic Extreme HD card on a 720p30 (square pixel) project using any and all RGB video output selections.
The issue is that when looking at it on my client monitor and reference monitor it is showing me more than the actual canvas. and won't grow to the full frame. I see additional area around everything i make, like it is showing me the outside areas of my working canvas.
any thoughts?
Matt Riggieri
Digital Cave Media
Peter Wiggins
Re: Apple Motion Video Output
on Jul 10, 2009 at 3:09:13 pm
Have you checked the output settings?
Peter
Andrew Pasternak
on Jul 14, 2009 at 8:08:52 pm
Yeah I would check your render output options like Peter suggested. Make sure they are set to the same dimensions that your project is set to. That would be my first inclination. Also maybe try to render out using Apple Pro Res 422 if that doesn't work. I've had similar issues using BlackMagic.
Matthew Riggieri
on Jul 14, 2009 at 8:23:23 pm
Figured it out.
There is a setting in the view menu called Show Full View Area. You must have that unselected fot proper output.
Matt
