trying to stabilize footage
COW Forums : Apple Motion
Nick Meyers
on Jul 9, 2009 at 6:32:09 pm
hi there.
i've been using FCP for 9 years, but am a novice when it comes to motion.
i've recently had some old super-8 footage telecined.
there's a fair bit of weave, and the frames ride up when a splice goes through.
we telecine with a bit of overscan, and the sprockets are visible in the left hand side of the frame,
so i figure i should be able to "pin" those sprockets somehow, and override the gate drift.
(the footage in the shots is hand-held, which is fine by me. i don't want to smooth that out, just get rid of the gate drift)
i've been trying to find how to do this in the manual, but am feeling a bit bamboozled.
(it says you can do this, but i can find where it outlines a process)
if its not to hard could someone outline the process (so an idiot can understand it!)
alternatively, if you can point me to some on-line tutes, that'd be great.
(I had a look for some, but most "stabilize " tutes deal with simply smoothing out a hand-held shot, or similar)
thanks,
nick
Ariane Fisher
Re: trying to stabilize footage
on Jul 10, 2009 at 4:31:23 pm
What kind of system are you using? Using motion for stabilization does work quite well, but is extremely processor and time consuming, even on a 2 second clip.
Nick Meyers
on Jul 10, 2009 at 11:07:37 pm
thanks for responding.
i'm on an 3GHz Octocore with 4G of ram.
since i haven't been able to figure out how to do what i want,
speed isn't my problem... yet!
would you have any tips on stabilizing shots by "pinning" certain points?
thanks,
nick
