Motion Layouts wont save
COW Forums : Apple Motion
Dixon Johnston
on Jun 30, 2009 at 7:32:39 pm
My Window layouts wont save.
Im working in Motion 2.
I dont know exactly where they are supposed to be saved, so I cant backtrack it that way. Basically, I rearrange the windows every time I open a project.
When I go to "save current layout", I enter the name in the field, "enter" and it goes away. It never shows back up under the layout tab, where I always have the same 2 options "Standard" and "Alternate"-"Cinema" is grayed out. Ive trashed preferences, and reinstalled the from the Motion 2 crossgrade discs.
Any advice is greatly appreciated.
Thanks in advance, Dixon
Dixon Johnston
Creative services Director-WRIC
Dual 2.0 G5, 4G RAM
OSX 10.4.1, FCP 5.1, QT 7
AJA Io-Beta SX (SDI)
Ariane Fisher
Re: Motion Layouts wont save
on Jun 30, 2009 at 9:34:39 pm
The UI layouts should be at:
userLibraryApplication SupportFinal Cut StudioMotionUI Layouts
Dixon Johnston
Thank you! Window Layout Problem Solved
on Jul 1, 2009 at 1:51:19 pm
Thank you! Problem solved
I couldn't find the folder because it didn't exist! Although I've reinstalled Motion 2 a few times, it never actually created the UI Layouts folder-weird! My solution, using your file path as a starting point was this:
I copied the folder from another Edit suite which had 2 saved custom window layouts, and put it in the right place on my machine-now everything is saving.
Dixon Johnston
Dual 2.0 G5, 4G RAM
