Simple transparent clockwise wipe
COW Forums : Apple Motion
Naiche Lujan
on Jun 12, 2009 at 10:32:44 pm
I must disclose I am very new to Motion. And the time has come to create a countdown (like the old movie countdowns).
I just can't figure out how to approach the wipe in Motion. I would think that there would be a preset in the Library, but haven't found it yet.
Any help would be appreciated.
Stephen Smith
Re: Simple transparent clockwise wipe
on Jun 15, 2009 at 2:45:29 pm
If you are trying to do the countdown where a number is in a circle and it wipes to the next number I would build that in FCP using the clock wipe. Hope this helps.
Stephen Smith
Lone Peak Productions
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Naiche Lujan
on Jun 15, 2009 at 4:05:44 pm
Thanks Stephen,
That is what I ended up doing, but I lack some control over the object(ie: it's not vector based, etc.). It would be preferable if it could be done in Motion. At least the way I have approached it.
Any ideas?
Naiche Lujan
on Jun 15, 2009 at 4:43:09 pm
Just going on your "make it in FCP" recommendation, is there a way to export the timeline with transparency layers? I'm not getting the contrast I want when importing into Motion. I can alter the opacity of the object, but again, it's not quite going right yet.
Stephen Smith
on Jun 15, 2009 at 4:44:47 pm
Two ideas:
1. In FCP, create a Black Color Matte and a white one. Put them both in the timeline and then add the clockwipe transition. Export that out as a movie. Import it into Motion and treat it as a Image Mask or Luma blend mode.
or
2. Create a mask and animate it.
Hope this helps.
Stephen Smith
Naiche Lujan
on Jun 15, 2009 at 8:04:46 pm
Thanks Stephen,
I think that'll do.
Stephen Smith
on Jun 15, 2009 at 8:27:49 pm
Very cool, happy to hear.
Stephen Smith
