swapping photos in your sequence
COW Forums : Apple Motion
pedro casais
on Jun 6, 2009 at 10:35:10 pm
Actually, I just found out the answer of that question, but I can seem to figure out how you change the order of the photos on your sequence. If you have 4 photos in your sequence 1,2,3,4 and before you export it to a qt file, you need to swap 2 and 3, how do you swap them in your motion sequence? I do have many more photos than 4, but it just to get the idea.
PC
Noah Kadner
Re: swapping photos in your sequence
on Jun 6, 2009 at 10:48:24 pm
Drag them on your timeline.
Noah
Check out my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Lens Adapter Guidebook, Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
pedro casais
on Jun 6, 2009 at 11:00:56 pm
I tried that but when I drag them it only overwrites the picture I need to swap it with. It doesn't work unless there's a key a need to hold before releasing the mouse to swap them and not overwrite it.
Noah Kadner
on Jun 7, 2009 at 1:56:59 pm
Yes it does work- if the photos are on their own tracks of course.
Noah
pedro casais
on Jun 7, 2009 at 3:19:15 pm
Noah,
Let me make sure I understand you, if you have a bunch of photos in your timeline, 1-2-3-4-5-6....and you want to swap 5 and 4 resulting in a new order, 1-2-3-5-4-6....you are telling me that if I drag 5 over 4 it will do the swap. And I tried that a few times and what it does is overwrites 4 resulting in a new order, 1-2-3-5-black hole-6.
So, unless you had select a preference option somewhere, by default is not working the way you're describing it if I am understanding correctly.
Can you describe the way you do it?
PC
Noah Kadner
on Jun 8, 2009 at 3:56:52 am
Is everyone on the same track or group? You can place each photo in a different level.
Noah
Glenn Sakatch
on Jun 8, 2009 at 9:20:41 pm
Pedro, the idea they are trying to tell you is to build a timeline with a different layer for each photo.
6 photos = 6 layers. Your final timeline would start out looking like a staircase, where layer 1's content ends, layer 2's contents start, and so on. Then if you want to swap 2 and 6, you simply drag 2s content down its section to where 6 starts, and you drag 6's content the other way to where 2 used to start.
I would also suggest playing with drop zones. Depending your your layout, a different drop zone for each photo can be easily changed from 1 photo to another.
You could also go into your media managment tab, and call up photo 2, and tell the program to use the file for photo 6 here instead.
Hope this helps.
pedro casais
on Jun 9, 2009 at 6:28:35 am
Thanks Glenn and Andy,
Those are really cool ideas.
best,
PC
