16:9 export wider than 16:9
COW Forums : Apple Motion
Vincent Strader
on Jun 3, 2009 at 11:03:12 pm
I taped in 16:9
Captured the footage in 16:9
Imported the 16:9 footage into Motion 3
After the project I started having the issues.
I select export
Export: Quick Time
Use: Current Project and Canvas Settings
Then I select OPTIONS:
In the video selection I click Advanced
Compression Type: DV/DVCPRO - NTSC
Aspect Ratio: 16:9
After I export the footage and then import it into my FCP project, I notice that the footage is slightly broader than the 16:9 original footage.
Hard to explain in text. Imagine two pieces of 16:9 paper on top of each other, and the exported one has been stretched out just a tad more to be bigger or wider.
Can somebody advise me what I am doing wrong?
Using Motion 3.0.2 , FCP 6.0.5
Vinnie
Vincent Strader
Re: 16:9 export wider than 16:9
on Jun 3, 2009 at 11:24:29 pm
NTSC Broadcast SD is also the setting I am using when I open up the project.
I'm taping in 16:9 using the DV setting on my JVC GY HD110
Sorry .. I figure too much info is better than not enough info.
Thanks again,
Vinnie
