Changing size after the pilot sketch
COW Forums : Apple Motion
alexandre hotton
on May 27, 2009 at 12:36:35 pm
Hello
I'm on a Begining credits project. I have to deviver in 1920/1080.
It's Heavy so I would like to work in 900/500 from my 3D app and when I'm happy, then recalculate in full HD.
I Know I can relink, but how could I do to get no problem. I use some particles.
Thank a lot
Alex
david bogie
Re: Changing size after the pilot sketch
on May 28, 2009 at 5:17:31 pm
Dangerously fraught with gotchas and unpredictable results that will clandestine and esoteric errors.
Umm, that won't tranlsate well. I shall rephrase:
Do not try to convert the smaller project to a larger project.
Experiment in the smaller size to learn how to create your effects. Use this as your skethboard, your draft editor, your roughcut assembly.
figure out what you can do to streamline and simplify such as render certain layers as complete movies.
But produce only in the larger size.
bogiesan
alexandre hotton
on May 28, 2009 at 7:19:15 pm
thanks
alex
Stephen Smith
on Jun 2, 2009 at 6:59:17 pm
I agree with bogiesan, I can see a lot of things going wrong. Keep in mind you can always work in the "Draft" render quality. Best of luck.
Stephen Smith
Lone Peak Productions
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
