Drop down menu
COW Forums : Apple Motion
Kevin Kimman
Drop down menu
on May 26, 2009 at 10:02:18 am
Hey,
I'm using motion for a while now, and I'm entering a project where I need to import layered files from Photoshop. But when I drag my layered .psd into the canvas the drop down menu doesn't show, so I'm not able to choose the option to import all layers.
I searched many forums, and apparently nobody has this problem, it should work properly but one way or the other it doesn't.
Please help,
Thanks.
Stephen Smith
Re: Drop down menu
on May 26, 2009 at 2:32:44 pm
I have had that happen every once and a blue moon. I saved the psd as a different name and that seemed to do the trick. Hope this helps.
Stephen Smith
Lone Peak Productions
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Kevin Kimman
Re: Drop down menu
on May 26, 2009 at 2:31:39 pm
Allright thanks,
But I think I solved the problem a few minutes after I posted this.
It turnes out that when I changed the color profile in photoshop from the standard sRGB IEC61966-2.1 to for example AppleRGB ,in the advanced options menu before opening a new project, the drop down menu in motion does show up, and I can choose to import all layers.
So it seems that motion3 can't see a layered .psd file when it's made with that particular color profile.....odd enough.
Thanks anyway
