render problems with some frames..
COW Forums : Apple Motion
stefan kroesbacher
on May 5, 2009 at 1:47:45 pm
hi all,
i'm facing serious trouble with a project of mine.
it's extensively comp'd, with different transfer modes, 3d particles etc.
problem is, in half resolution render everything's fine
in full (1080p) either in compressor or motion itself,
some frames make trouble..
transfer modes and masks seem to fail, leaving the frame with
artifacts...
next frame's good again...
then again somewhere problem...
known problem?
what makes motion fail?
opengl?
ram?
10.5.6, x1900xt
thanx for input
stefan
Stephen Smith
Re: render problems with some frames..
on May 5, 2009 at 3:25:03 pm
The only time I've ever had a problem like that is when the Render Quality is not set to Best when it should be. Make sure everything is set to Best. If that doesn't work I would make sure I have the newest update of Motion. Hope this helps.
Stephen Smith
Lone Peak Productions
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
stefan kroesbacher
on May 5, 2009 at 6:16:11 pm
found the problem:
"Beam" Generator makes the trouble.
strangely in ram preview everything works,
but whichever setting i use, expoting in full
res an best or normal doesn't work.
i think i have to render proxies for the beam effekt...
sad but true...
or simply my x1900xt can't handle the project.
will try with a new machine and a 4870 in a few dayz
thanx
