progressive screengrabs to uncompressed interlaced SD
COW Forums : Apple Motion
Paul Griffiths
on Apr 27, 2009 at 1:49:23 pm
Hello!
Any help with this little problem would be much appreciated
I've captured some screengrabs from the internet with iShowU into Apple Animation 1920x1080 at 24p (as I didn't want this program to interlace or scale anything).
I've then imported these into an uncompressed PAL SD (FHA) Motion project in order to pan and zoom around it.
Then I rendered these out as uncompressed PAL SD quicktime files (upper field dominant) and dropped into an uncompressed PAL SD anamorphic (upper field dominant) timeline.
However! When I play these back on my PAL SD SDI broadcast monitor (an old grade 1 CRT) I still get a bit of flicker on the pans and zooms. I realise this might be the thin lines on the website rippling over the interlacing but am I missing anything else?
Dropping in the .motn files into the FCP timeline and rendering produces the same thing. Have I missed a checkbox somewhere? Should I be using compressor?
Any thoughts/questions would be really useful.
Paul G
Delivery medium: PAL SD DVD
Timeline: Uncompressed PAL SD mixed with PAL DV footage
OSX 10.5.6
QT 7.6
FCP 6.0.5
Motion 3.0.2
Quad core Intel Mac Pro 8GB RAM
SCSI RAID
Stephen Smith
Re: progressive screengrabs to uncompressed interlaced SD
on Apr 27, 2009 at 2:32:27 pm
In FCP I would add a Flicker Filter to the file to get rid of the flicker. Hope this helps.
Stephen Smith
Salt Lake Video
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Paul Griffiths
on Apr 27, 2009 at 2:55:21 pm
Hi Stephen,
Thanks for your help - doesn't the flickr filter do a deinterlace or blur? I don't want a drop in quality but if this is the only way... Incidentally I just rendered out some PAL DV video from motion as uncompressed PAL SD and this has the same flicker on it - I thought Motion would shift the fields for me...
Stephen Smith
on Apr 27, 2009 at 11:42:14 pm
The flicker filter adds vertical softness. Those darn thin lines are doing you in. Another way to get rid of them is to zoom into the web page further so the thin lines become thicker. Hope this helps.
Stephen Smith
Salt Lake Video
Paul Griffiths
on Apr 28, 2009 at 10:59:32 am
Hi Stephen,
That does help, thanks for your time,
Paul
Stephen Smith
on Apr 28, 2009 at 3:37:01 pm
No problem, happy to help.
Stephen Smith
Salt Lake Video
