Cutting or shortening clips... possible??
COW Forums : Apple Motion
Josh Evans
on Apr 27, 2009 at 4:34:47 am
Often I need to shorten a clip by cutting off the end. I cant seem to do this in motion.
So If i try to drag one end of the clip to shorten it, it moves the video around in my composition putting everything out of sync.
is there a way to do what i want? seems like there should be.
The shortening thing works sometimes, but other times just moves things out of sync. Weird.
Noah Kadner
Re: Cutting or shortening clips... possible??
on Apr 27, 2009 at 6:19:23 am
Clips can be trimmed with the in/out commands- i and o on your keyboard.
Noah
Check out my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Lens Adapter Guidebook, Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Josh Evans
on Apr 27, 2009 at 6:44:20 am
wow i cant believe i didnt know this.
Thanks so much it works perfectly for the project i was having trouble with.
Cheers,
J.
Josh Evans
ARGH still problems
on Apr 27, 2009 at 8:24:12 am
That seemed to work but then now it doesnt.
For some reason, when i shorten the end or beginning of a clip, the whole thing jumps around. Not in the timeline, because it stays put there, what i mean is all the frames within the clip jump, as if i am doing a Timeslip, when in fact all i want to do is trim the beginning or end off. Whats going on?
