exporting a movie in a left and right side
COW Forums : Apple Motion
Henrik Bjoerlin
on Apr 4, 2009 at 9:37:30 pm
I am working on a motion project 2460px x 768px.
Now I need to export this movie in a leftside part and a rightside part to compress and later join together in Watchout. I would like to split the movie in two 1230x768 parts.
To do this I have tried to simply change the project properties to 1230x768. Motion then by default centres all media in the resized canvas.
Does anyone know a way to reposition all the media in a simple way?
I would like to avoid to reposition every item of media in the project.
Any other ideas on how to go about this?
Henrik Bjoerlin
Re: exporting a movie in a left and right side
on Apr 5, 2009 at 7:15:57 am
I came up with the solution myself. You just put all the groups in a new group. Then you reposition that group where you want it.
Peter Wiggins
on Apr 5, 2009 at 11:48:21 am
repeating a thread from another forum, the best answer was to export out a full resolution quicktime,
then make two copies/exports in QuicktimePro by adjusting the geometry/size.
Josh Paulson
on Apr 7, 2009 at 1:43:20 pm
I did a similar set-up with 5 HD monitors. My trick was to position a camera in each of the 5 sections, and when exporting, I chose which camera I wanted in the advanced export settings.
Donnie Mallkerb
on May 20, 2009 at 4:22:00 pm
I have a similar problem. but with after effects i guess
i need to export a 5120 x 768 file split into five 1024 x 768 files. im wondering what would be the easiest way to do this, if i already have video files rendered at 5120 x 768.
the camera idea for each section might work in after effects??? i will try that out... I am unsure how accurate that might be though...
any ideas? an alternative or stand alone app that might help?
iim on mac osx btw
thanks guys
