pond ripple / blip effect
COW Forums : Apple Motion
Alex Jones
on Feb 12, 2009 at 1:09:59 am
Hi Guys, really basic i'm sure...
trying to create a sonar/blip/pond ripple effect.
Center emitting rings that scale up and fade out, can'y get the hang of the emitter?
please help
thanks,
Jonesy
Jonathan Fraser
Re: pond ripple / blip effect
on Feb 21, 2009 at 3:34:38 am
You actually don't need an emitter for this. Create your ring using your shape tool and when you're ready to animate it create one instance of the ring's growth that you want using keyframes. Then in your keyframe editor select the animated parameters and right click the keyframe button thats just to the right of the values. Scroll down to "after last keyframe..." and hit repeat. Hope this helps or at least gets you closer to what you need.
Jon F
