Page Peel
COW Forums : Apple Motion
Stephen Smith
Page Peel
on Feb 10, 2009 at 9:02:39 pm
I'm looking for a plug-in that creates a page peel for Motion. One that works with Alpha Channels and lets you animate the page curl so you can choose to not let it peel all the way. Basically, one that operates like the AE page curl. And I'm looking for an answer other then "use AE then". Thanks.
Stephen Smith
Salt Lake Video
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Stephen Smith
Re: Page Peel
on Mar 6, 2009 at 12:59:43 am
Stink...I was looking for an answer other then silence.
Stephen Smith
Salt Lake Video
Chad Lindsey
Re: Page Peel
on Nov 6, 2009 at 7:04:59 pm
Any luck on finding this Stephen?
I have searching aimlessly and have not found anything yet.
Thanks, Chad
Stephen Smith
Re: Page Peel
on Nov 6, 2009 at 7:45:52 pm
Sorry, I have not had any luck. I was hoping that that would be included with Motion 4, but no dice. If you find anything let me know.
Stephen Smith
Utah Video Productions
Check out the Graphics Demo Reel I did.
Check out my Motion Tutorials
Alex Kaloostian
Re: Page Peel
on Feb 21, 2010 at 12:58:57 am
How about using the Page Peel transition in FCP, then exporting a MOV with an alpha channel?
"I'm Alex Kaloostian, and I approve this message."
Stephen Smith
Re: Page Peel
on Feb 22, 2010 at 4:38:21 pm
Thanks Alex, but for me, the Page Peel transition in FCP won't let you place an object such as a .psd with an alpha channel in its back. If you do, it turns the Alpha Channel black. Hopefully Motion 5 will have a page peel much like After Effects. Just my two cents.
Stephen Smith
Steve Delasantos
Re: Page Peel
on Oct 13, 2010 at 6:48:40 pm
What about using the CURL filter in FCP? That's pretty controllable.
Stephen Smith
Re: Page Peel
on Oct 14, 2010 at 3:35:12 pm
Steve,
The Curl filter is really cool and I didn't know about it. However, it will not work with alpha channels as well. Instead of making a part of an image see through where the alpha channel is it makes it black. If you wanted to flip though an old book with rough (torn) edges it would be black on the edge whereas in After Effects it will be transparent.
Stephen Smith
Steve Delasantos
Re: Page Peel
on Oct 15, 2010 at 12:48:01 pm
That's right, I forgot about it not working with the alpha channel. Oh well, worth a try. Good luck!
Steve
Stephen Smith
Re: Page Peel
on Oct 15, 2010 at 6:20:58 pm
Looks like I'll keep using After Effects for my page peels.
Stephen Smith
Francis Baconnaise
Re: Page Peel
on Sep 23, 2012 at 3:17:12 am
I have an idea...
What if you use the curl feature in FCP, duplicate your media and stack them on V2 and V3, leaving V1 empty. Then with the copy on V2, play with any of the color, gamma, or brightness & contrast controls until you have what is essentially an alpha channel. Then set the composite mode on the V3 copy to Travel Matte Luma.
The V3 clip will use what lies directly beneath it as a Matte. White shows, black is transparent and passes through to whatever lies on V1.
Stephen Smith
Re: Page Peel
on Sep 24, 2012 at 4:18:32 pm
Francis,
Thanks for the idea but AE is much easier to use with a page peel. Take a look at this
I did.
Good news for anyone on Motion 5. The page peel was added.
Stephen Smith
Check out my Vimeo page
Albert OConnor
Re: Page Peel
on Jan 3, 2013 at 4:08:46 pm
How 'bout mixing the satisfratis with the radabum to get a doo-ran doo-ran you then matte and then invert key over it?
Bob
