Write on with pen tool, low opacity in FCP
COW Forums : Apple Motion
Bret Yager
on Feb 5, 2009 at 8:03:51 pm
I am using my pen tool and creating a write on effect to a logo. Everything looks like it works very smoothy in Motion. When i save the motion file and import into FCP and overlay existing video footage. It is there but very very vague. I actually duplicated the motion layer up to 20 times to start to see my Motion work over the video footage.
In Motion I have my Logo PSD at the top of my group with the blending mode set to Stencil luma. Underneath that layer is all of my pen tool layers with "write on" selected. When I hit play, all the the motion and such that is supposed to happen, does. Once in Final Cut its like the clip has an opacity setting of 1.
Any Suggestions? Thanks
http://www.yagervideo.com
walter biscardi
Re: Write on with pen tool, low opacity in FCP
on Feb 5, 2009 at 8:19:28 pm
First, make sure you're rendering with an alpha channel.
Then in FCP.
Click on the Clip > Item Properties > Alpha > Black
See if that helps.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
Read my Blog!
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Bret Yager
on Feb 5, 2009 at 8:24:53 pm
thanks,
It was exported in Motion with Color+Alpha selected. In final cut when I select clip/item properties/format/ it shoes alpha is set to black
Bret Yager
on Feb 5, 2009 at 9:24:25 pm
i have uploaded a video so you can see what I am talking about.
http://yagervideo.com/test.mov
The first part of the video, i had to jump through hoops to get too and my results are not as clear and high as I anticipated. The Outlined Deer is supposed to be the same color as the word whitetails when it appears. But i am lossing video somewhere in my process
the 2nd part of the video is just my .motn file imported into FCP.
Hope this helps.
Peter Wiggins
on Feb 5, 2009 at 11:56:52 pm
What does it look like in Motion over the chequerboard background?
Peter
Bret Yager
on Feb 6, 2009 at 2:44:54 pm
Hey Peter,
Its actually a black background.
Peter Wiggins
on Feb 6, 2009 at 2:53:24 pm
Yes, but if you toggle to the chequerboard it will show the transparency of the strokes better.
Peter
Bret Yager
on Feb 6, 2009 at 4:07:03 pm
ok, i did and yes the stokes barely show up. I guess I don't know how to correct that. here is what the settings for my strokes are... thanks!
Peter Wiggins
on Feb 6, 2009 at 4:36:13 pm
That will be the reason they don't show up in FCP!!!
Is it a pen pressure/opacity thing?
Peter
Bret Yager
on Feb 6, 2009 at 4:39:32 pm
well my brush opacity is set to 100% as shown in the image i attached.
Andy Neil
on Feb 8, 2009 at 7:16:33 am
I think your problem is related to the Stencil Luma blend mode on your PSD.
