apple motion swap image for text
COW Forums : Apple Motion
Laura Gruszczynski
on Jan 15, 2009 at 8:45:04 pm
I have a dilemma,
I created an animation using multiple question marks in Apple Motion,
Each one has a simple move behavior attached to it.
I am now trying to swap out the text for an image of a question mark that is not available as a font.
I tried to drag and drop the image onto the layer but apparently I can't swap a text layer with an image.
How can I copy all of the text layer attributes (position, scale and motion etc.) to the image layer without having to re-animate each layer?
is it even possible?
Thanks, Laura
gruszla
Stephen Smith
Re: apple motion swap image for text
on Jan 15, 2009 at 10:01:20 pm
If you created keyframes to say the Position: Select the text layer. Hit F1 to open up the Properties tab. Click on Position (It will turn a darker gray) and drag it onto your image. The position key frames will be applied to the image.
Behaviors can be copied and pasted onto an image.
Hope this helps.
Stephen Smith
Salt Lake Video
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Laura Gruszczynski
on Jan 16, 2009 at 2:36:03 pm
It helps a lot,
Laura
gruszla
Stephen Smith
on Jan 16, 2009 at 3:57:01 pm
Very cool.
Stephen Smith
Salt Lake Video
