preview window goes to black and renders black...
COW Forums : Apple Motion
john wheeler
on Jan 15, 2009 at 6:35:08 pm
Can someone help me here? I am working in an SD timeline (around 10 secs) and for some reason, out of no where, my preview window turns black, like motion can't handle the information or something? Not for sure, but I started in "best" moved all the way down to "draft" mode and cleared the ram preview and get the same results, so then I restarted, it works for a bit, but then if I try to move forward it starts up again.
I am using several mask, and I need to use the mask, but can motion not handle the work load? Any help, and I don't believe it is my system, running on a mac (2 x 3.2 GhZ Quad Core Intel Xeon) 10 GB memory...>>>??
Thank you
