Copying an effect from one clip or project to another.
COW Forums : Apple Motion
Steve Cohen
on Nov 6, 2008 at 9:03:16 pm
Is there a way to copy and paste the attribute of an effect from one clip to another or even from project to project.
I have to composite an image in to a TV monitor in several scenes.
They are all in the same position because the camera was locked down.
Is there a way to copy an paste attributes like you can in Final Cut.
Thanks;
Steve Cohen
Editor
O2 Media Inc.
Noah Kadner
Re: Copying an effect from one clip or project to another.
on Nov 6, 2008 at 9:52:17 pm
Have you tried adding the effect, behavior or filter into your favorites folder?
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
http://www.callboxlive.com
Stephen Smith
on Nov 11, 2008 at 12:22:16 am
[Steve Cohen] Is there a way to copy and paste the attribute of an effect from one clip to another or even from project to project.
You can copy and paste any Behavior or Filter. If it is a key framed movement such as the scale. Select the clip you want to copy the key frames from. Hit F1 to open up the Properties window. Select the parameter and drag it to your other clip and it will inherit the same key frames. Hope this helps.
Stephen Smith
Salt Lake Video
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Steve Cohen
on Nov 11, 2008 at 1:06:37 pm
That sounds perfect.
I will have to remember to try it the next time I have the chance.
The problem is that our workflow does not require Motion that often and by the time I go back to it I have forgotten what I learned last time.
Thanks again;
Steve Cohen
Editor
O2 Media Inc.
Stephen Smith
on Nov 11, 2008 at 4:11:51 pm
No problem Steve. Thanks for the question.
Stephen Smith
Salt Lake Video
