frame rate change
COW Forums : Apple Motion
mike moncrief
frame rate change
on Oct 18, 2008 at 8:14:59 pm
Hello,
Got a bit of a problem.. I rendered a quicktime using the animation codec out of a 3d program on a Mac( Lightwave 3d) And after a long render, I went to play the quicktime and it plays back like there is only 4 frames.. (210 frame were rendered out) when I look at the item properties on the file I see it says it the right lenght, but it rate is 3000 frames per second... I can scrub through and see all the frames are there .. just cannot get it to play back correctly.. So is there a way to change it to 29.97 frames per second ??
Thanks for any help in advance..
Mike Moncrief
Noah Kadner
Re: frame rate change
on Oct 20, 2008 at 12:20:07 pm
Check it in the QuickTime Player- make sure all frames were actually rendered. I typically render 3D to image sequences rather than movie files just in case something like this happens you can render a frame at a time to replace the lost frames rather than have to do the whole thing over every time.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
http://www.callboxlive.com
