From Motion to Visualhub to Flash with alpha channel. Possible?
COW Forums : Apple Motion
William Flanagan
on Sep 13, 2008 at 10:33:17 pm
I'm trying to take a motion clip (rendered in Quicktime) and for a flash web banner (see http://www.tempusgroup.com/alpha). In previous renders, the trip to FCP first gave me a nice alpha channel (but made everything look very rough). I'm trying to skip that step.
Does anyone know of a good way to either use VisualHub or Compressor to encode a Quicktime with an alpha channel, so that it's transparent when I post it up on the website?
Banging my head against the wall on this one. I don't want to go to FCP to get my alpha! :-)
Help.
William
Edward Glasheen
Re: From Motion to Visualhub to Flash with alpha channel. Possible?
on Sep 14, 2008 at 12:43:15 pm
I am assuming that you have Flash so I would not compress your file in Visual Hub or Compressor because Flash will compress your footage again when you compile it.
I usually bring my Motion footage into Flash using Animation + codec set at the highest quality. I'll let Flash convert it to .flv making sure the Alpha setting is checked.
If the file is short, such as an explosion, I may convert to a .swf file and convert it to a movie clip.
I think your jaggy quality may be a result of re-compression and / or not de-interlacing your video.
Ed
