Swap Files to recycle behavior?
COW Forums : Apple Motion
Chad Johnson
on Sep 11, 2008 at 9:58:17 pm
Hi
I have a motion file with a keyframed bouncing ball, and a simple camera move. It's a black background with a white ball. I would like to now have a black ball doing the exact same thing with a white background. So I did a save-as to make a new project, and would like to just swap out the white ball with a new black ball graphic.
How is that done?
Chad
My Music: http://www.humboldtmusic.com/chadjohnson
My Work: http://www.precisionintermedia.com/video_sample.html (Video & Jingles)
My Fun Video: http://www.youtube.com/chadfish
Stephen Smith
Re: Swap Files to recycle behavior?
on Sep 11, 2008 at 10:11:33 pm
If you created the ball and background in Motion you can just change their color. You could add a Invert filter which will allow you to change black to white visa versa. If you created the ball in a program such as PhotoShop just drag the new ball over the old one. Motion will create a hooked shaped arrow. Let go of the mouse and it will swap out the old clip for the new one, that way you don't have to make any changes...if the two balls are the same size that is. Hope this helps.
Stephen Smith
Salt Lake Video
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Chad Johnson
on Sep 11, 2008 at 10:28:40 pm
Thanks Stephen
I was working with photoshop files of the same size. So the drop onto the layer worked perfectly.
Regards.
Chad
Stephen Smith
on Sep 11, 2008 at 11:04:20 pm
Sweet, I'm so happy to hear that it worked out.
Stephen Smith
Salt Lake Video
