Import Illustrator Files Unmerged
COW Forums : Apple Motion
Chris Dixon
on Sep 8, 2008 at 3:07:37 pm
I'm trying to import a layered vector based Illustrator file into motion.
When I do it always merges the layers. I've tried converting to pdf, but get the same results. Any suggestions?
Thanks.
Miriam Moran
Re: Import Illustrator Files Unmerged
on Sep 8, 2008 at 4:07:32 pm
I don't use illustrator, but to import a layered Photoshop file you need to use, from the menu, "File" -> "Import" then select the file you want. You are then prompted for "merged layers" or "all layers" choices.
Good luck!
Jim Johnson
on Sep 8, 2008 at 5:00:44 pm
Howdy,
Illustrator files are imported as a merged PDF. It's all vector data, so it can be dynamically rasterized, but it's merged, so no layers.
