Can a SD motion template be converted to HD?
COW Forums : Apple Motion
David Hunter
on Aug 12, 2008 at 8:14:15 pm
I have a Motion template in SD aspect ratio I would like to use for my DVCPRO HD 960X720 project in Final Cut pro.
I have Motion set for the DVCPRO HD preferences when starting a new project or in exporting video.
Is there a way to reset all the aspect ratio values for this Motion template globally to convert it to one that I can customize for editing in the HD 960X720 aspect? I have project properties set for 960X720.
I notice right now that I cannot even manually change the values on individual layers for such things as graphics from 70X576 dimensions. Of course, I can manually reset handles but this is sloppy. The provision for writing in the dimensions is greyed out.
Is there a way to globally at least reset the width and height and save as a template copy suitable for tweaking in HD?
Thank you!
