How to remove black border/frame from keyed layer
COW Forums : Apple Motion
Tom Hancock
on Aug 6, 2008 at 12:58:48 pm
I am currently working on a scene which involves layered still images and also some footage of a person shot in front of green screen which I have since keyed out using Motion's Blue/Green Screen filter - which is placed in the foreground of the 3D 'space'. The problem I'm having is that there appears to be a sort of 'dancing' black edge which outlines the entire frame of the keyed layer. If for example I use the crop tool to say remove the outer left/right areas of the layer, the black outline simply changes shape to match the new cropped shape of the layer.
Is there a simple way to get rid of this?
Cheers
Stephen Smith
Re: How to remove black border/frame from keyed layer
on Aug 6, 2008 at 2:35:58 pm
Try the mask tool on the keyed clip. Hope this helps.
Stephen Smith
Salt Lake Video
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
david bogie
on Aug 6, 2008 at 3:57:45 pm
[Tom Hancock] "he problem I'm having is that there appears to be a sort of 'dancing' black edge which outlines the entire frame of the keyed layer. If for example I use the crop tool to say remove the outer left/right areas of the layer, the black outline simply changes shape to match the new cropped shape of the layer. "
No idea what you mean by that last part.
Black edges around a keyed source are usually simply alpha interpretation settings for the layer. Change yours.
did you prerender the greenscreen key? Nest it?
bogiesan
This is my standard sigfile so do not take it personally: "For crying out loud, read the freakin' manual."
Noah Kadner
on Aug 7, 2008 at 1:22:57 am
Draw a bezier mask around the shot to remove the black areas. It's called a garbage matte in old-school compositing terms.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
http://www.callboxlive.com
Tom Hancock
on Aug 7, 2008 at 4:20:17 pm
Thanks for the replies. After trying the first two, I was recommended to install the software update (3.0.2) then - magically - problem solved. Weird, but good.
Stephen Smith
on Aug 7, 2008 at 4:53:00 pm
How funny, I'm glad that solved the problem.
Stephen Smith
Salt Lake Video
