Replace Footage?
COW Forums : Apple Motion
John Felt
Replace Footage?
on Jul 5, 2008 at 11:47:08 pm
Hi all
I am working on a project where I need to swap out some footage to replace it with other updated footage. The new footage and old footage are the same size, so I just want to be able swap out the old for new. Essentially give all the old property values to the new footage.
Is there a way to easily just replace footage? It's fairly simple in After Effects so I figured there would be a way in Motion, but I can't seem to find it.
Thank you all for you help. It is always enormously appreciated.
Thanks, John
Colin McQuillan
Re: Replace Footage?
on Jul 6, 2008 at 9:28:50 pm
Drag and drop the new footage over top of the old. It will retain all the formating/key frames so on... of the clip it's replacing.
Make sure you see a box appear around the lower (old) clip. If you see a line below or above the clip you want to replace, you will only add the new clip to the group, not replace the old clip.
Colin McQuillan
Van. B.C.
Colin McQuillan
on Jul 6, 2008 at 9:50:03 pm
Do this in the Layers tab (F4)
Colin McQuillan
Van. B.C.
