16:9 template
COW Forums : Apple Motion
Luke Pearson
16:9 template
on Jun 13, 2008 at 3:21:01 pm
I'm using a template in motion and when I change the project to anamorphic in the project properties, some of the aspects of the project distort or don't fill the screen. How can I make the template 16:9 with no problems? Thanks in advance guys.
Luke Pearson
http://www.LiftFilms.net
Do not forget to entertain strangers, for by so doing some have unwittingly entertained angels.
-Hebrews 13:2
Stephen Smith
Re: 16:9 template
on Jun 19, 2008 at 7:01:26 pm
What template are you using? I just changed the "Sketch-Open.NTSC" template to 16x9 anamorphic and it did not stretch while maintaining it's proper aspect ratio.
Stephen Smith
Lone Peak Producitons
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Luke Pearson
Re: 16:9 template
on Jun 19, 2008 at 7:39:21 pm
Thanks for the response Stephen. i was using the paint template. It didn't change all the layers. just some of them.
Luke Pearson
-Hebrews 13:2
Stephen Smith
Re: 16:9 template
on Jun 19, 2008 at 8:18:58 pm
I would love to try to re create the same problem. What is the exact name of the the template?
Stephen Smith
Luke Pearson
Re: 16:9 template
on Jun 19, 2008 at 8:20:51 pm
Its the "Brush Strokes-Open" template NTSC
Luke Pearson
-Hebrews 13:2
Stephen Smith
Re: 16:9 template
on Jun 19, 2008 at 11:09:14 pm
I see what you mean. I'm not sure if there is an answer for that. Here is a quick fix for this problem:
-Edit
-Project Properties
-Change the Height to 405 (16x9 Anamorphic is really 720 x 405)
Everything fits like it should in motion and the project file will open up just fine in FCP, regardless if it is 720 by 480 or 720 by 480 anamorphic. Hope this helps.
Stephen Smith
Luke Pearson
Re: 16:9 template
on Jun 20, 2008 at 1:58:59 am
I just tried your suggestion and it doesn't seem to fit inside of an anamorphic timeline correct. It leaves space on the outside edges.
Luke Pearson
-Hebrews 13:2
Stephen Smith
Re: 16:9 template
on Jun 20, 2008 at 1:26:57 pm
Sorry, I just gave you the aspect ratio for 720 by 480, you must be working with 720 by 486:
720 x 486 = 720 x 410
720 x 480 = 720 x 405
Hope this helps.
Stephen Smith
