Applying a motion blur
COW Forums : Apple Motion
matt rinaldo
on May 22, 2008 at 6:37:16 pm
Does anyone know if there is another way to create a motion blur effects other then clicking view>motion blur? If you create a motion blur the way i mentioned above how to you tweak the amount ? And also how can I select which elements get a blur and which do not?
thanks for your awesome help
matt rinaldo
Stephen Smith
Re: Applying a motion blur
on May 23, 2008 at 1:46:51 pm
You can tweak the amount by going to Edit, Project Properties, Render Settings. It should look very familiar to FCP’s Motion Blur settings and it works the same way. It is putting a blur on anything that moves. Hope this helps.
Stephen Smith
Lone Peak Producitons
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Jeff Greenberg
on May 25, 2008 at 6:23:00 am
Unlike AE (are you an AE guy?) - Motion blur is an all or nothing deal.
Project properties, permit you to adjust it.
There's also a motion blur filter, which I guess you could use on specific objects.
Best,
Jeff G
Principal Instructor
Future Media Concepts
FMCTraining.com
Editorsretreat.com
matt rinaldo
on May 25, 2008 at 8:35:44 pm
well i am an aspiring "AE guy" i know that in ae you can select the motion blur toggle switch to turn motion blur on to indiviual layers. In motion I have played with the Movement blur filter but it did not look like i was hoping it would, it was just a little choppy and I played with the hud display and could not get it right.
I like motion im using it at work often and have been getting good results. I started to play with motion before i picked up AE and it is a little more answer friendly.
in the future i am undecied about which program i will use primarily
