File Browser/Inspector is stuck
COW Forums : Apple Motion
Patricia Stitson
on May 15, 2008 at 8:40:42 am
After having Motion up on my computer for only a short time I 'lost' the File Browser/Inspector, etc panel and I can't get it back. I've been resorting to using a locked inspector but that is not very user friendly. Do I need to reinstall?
Any input would be appreciated.
Stephen Smith
Re: File Browser/Inspector is stuck
on May 15, 2008 at 3:55:00 pm
You may have accidentally hit the Command and 1 keys. What happens when you hit the Command and 1 keys?
Stephen Smith
Lone Peak Producitons
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Patricia Stitson
on May 15, 2008 at 4:36:31 pm
Tried that too. Tried a reinstall...still nothing. arghh. :)
Stephen Smith
on May 15, 2008 at 9:19:50 pm
Blast, it was worth a try. Uninstalling applications can be very difficult. Apple’s official document on how to uninstall compressor is super long. I tried to dig up Motions but it appears to be no longer available. I found this application that will do the job. I’ve never used it…so if you do end up using it let me know how it does. Hope this helps.
Stephen Smith
Patricia Stitson
on May 16, 2008 at 2:31:39 am
I found an app called appzapper and it got the uninstall job done.. I reinstalled and... dah dah dah daaah... low and behold my file browser reappeared.. who knows.. Motion gliche or I somehow moved it WAY offscreen?
Thanks for your response tho!
Stephen Smith
on May 16, 2008 at 2:39:20 pm
Very cool! I'm happy that appzapper worked.
Stephen Smith
simon li
on May 19, 2008 at 10:13:09 pm
hey whats appzapper I have the same thing
I was just gonna add some smoke to follow the motion tracker and
then all of a sudden the program crashed. I tried to load up motion again and the stupid thing doesn't load file browser.
Is it like final cut pro where you have to remove a few things to get factory settings? or do you have to remove software and reinstall.
please help me
If I knew how to use this thing i wouldn't ask
Stephen Smith
on May 19, 2008 at 10:32:01 pm
AppZapper and FCS Remover remove the whole program. They’re not like FCP Rescue were they only remove your Final Cut Pro preferences. Looks like we need a Motion Rescue program.
Stephen Smith
simon li
on May 20, 2008 at 10:29:01 am
Thanks Stephen, I removed the program and used the install disc.
fingers cross if its gonna do this again.
great web site by the way I'm learning a lot
Stephen Smith
Re: Thanks
on May 20, 2008 at 2:10:40 pm
Simon, I’m happy AppZapper worked. Thanks for the kind words.
Stephen Smith
Patricia Stitson
Motion fix
on May 20, 2008 at 3:55:11 pm
Hey,
Appzapper can be found at http://www.appzapper.com/. It will unintall motion and then you can start with the FCP install disc. Installer will automatically know that Motion needs to be installed and will guide you through the process.
Hope this helps.
Matt Gerard
Re: Motion fix
on Jun 4, 2008 at 9:25:43 pm
Just a silly idea, but this happens all the time with me when my boss (with dual 23" cinema displays) starts a project and I need to take over (with 19"NEC displays). Have you tried restoring the default screen layout? Just incase, like you said, the pallet got moved off your screen.
Just an idea ;-)
Matt
Its more fun to ride a slow motorcycle fast than a fast motorcycle slow...
cowcowcowcowcow
Rob Mitchell
Re: Motion fix
on Sep 21, 2008 at 3:02:00 am
There is a MUCH easier way to fix this problem than deleting and reinstalling Motion. All you need to do is delete the user plist file (thanks to the Apple's Motion boards for this info):
From Finder press Shift/Command/H to go to your user account home folder.
From your user account home folder go to Library/Preferences/com.apple.motion.plist
I urge people to fix this problem using the 5 second fix before going to the trouble of deleting and reinstalling Motion.
Graham Hardie
Re: Motion fix
on Dec 19, 2008 at 5:01:53 pm
Brilliant solution and it worked!
Now, why did it disappear to begin with and what did I do?
Rhiannon Windred
Re: Motion fix
on Jan 31, 2011 at 4:06:39 am
Awesome! Problem fixed!!
