Optical flow retiming loses clip interlacing
COW Forums : Apple Motion
Paul Escandon
on May 1, 2008 at 5:21:55 pm
So I sent a DVCPRO HD 1080i clip in a DVCPRO HD 1080i timeline from Final Cut to Motion 3 to retime it to 50%. I performed this retiming using optical flow and when I saved and rendered the motion clip in Final Cut - the interlacing was gone. Checking back in motion - I see that the interlacing appears to still be there after the retiming has occurred.
What am I doing wrong here? Or is this a limitation of Motion's optical flow retiming that I wasn't aware of? I'm not rendering out the file from Motion 3 - I'm just saving the project and rendering the embedded .motn clip back in FCP.
Thanks.
Paul Escandon
Producer | Director - Oremus Productions
oremusproductions.com |
Tom Brooks
Re: Optical flow retiming loses clip interlacing
on Nov 2, 2008 at 2:37:20 pm
Did you try setting rendering of Motion projects to Best in your FCP sequence settings? Normal setting doesn't seem to get you certain properties from Motion.
