Best Camera Setting for Optical Flow Retiming
COW Forums : Apple Motion
Michael Jones
on Apr 24, 2008 at 4:42:07 pm
Hello,
I'm going to shoot some kids jumping in front of a green screen (SDX900 Records DVPRO50). I will probably slow it in post using Apple Motion's New Optical Flow Retiming tool. I like to shoot 24p for the look, but I realize it all ends up interlaced in FCP anyway. (Looks Aside) Should I go to 30p or 60i on the camera mode? I figure I should add 1/100 or 1/120 Shutter, but I want to get as much info to Motion for the retiming.
Noah Kadner
Re: Best Camera Setting for Optical Flow Retiming
on Apr 24, 2008 at 8:47:16 pm
Make sure you're sequence setup for progressive or none- you should be able to get nice progressive retiming out of FCP. If not, try Motion.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
http://www.callboxlive.com
david bogie
on Apr 24, 2008 at 10:02:03 pm
If you want to render better slow motion, you must provide as many time slices as you can. Dunno that camera but I'd shoot 60i, 60p, or as high as will possibly go.
Using film, you'd overcrank at 72-1444 frames per second for elegant and sexy slow motion.
Smoothcam is an unpredictable kluge. Might work. But feed it more frames if you can.
bogiesan
This is my standard sigfile so do not take it personally: "For crying out loud, read the freakin' manual."
Noah Kadner
on Apr 25, 2008 at 6:21:00 pm
Or rent a Phantom for 1000fps full 2K.... TIGHT:
http://www.callboxlive.com/resources/?p=76
-Noah
david bogie
on Apr 25, 2008 at 7:12:37 pm
[Noah Kadner] "Or rent a Phantom for 1000fps full 2K.... TIGHT: "
Oh, yeah, baby! Major drool factor there!
bogiesan
