Timer Countdown in Motion 3…???
COW Forums : Apple Motion
Phil Muri
on Apr 8, 2008 at 4:40:08 am
Is it possible to create a digital countdown timer in Motion 3? For example, starting at 60 minutes and ticking down all the way to 0?
-Phil
Burt Hazard
Re: Timer Countdown in Motion 3…???
on Apr 8, 2008 at 8:55:01 pm
It's possible, but pretty tedious because you'd have to do it manually. Motion doesn't have a text generator/behavior for it yet (Motion 3.5.1?).
Digital Heaven does have a counter plugin for FCP itself though ($20).
david bogie
on Apr 9, 2008 at 3:55:54 pm
You can also use the timecode generator in FCP over a slug. but you have no control over typefaces and other subtleties.
bogiesan
This is my standard sigfile so do not take it personally: "For crying out loud, read the freakin' manual."
Arnie Schlissel
on Apr 9, 2008 at 4:53:15 pm
Better than using a slug, you can make a black .tiff or .tga or .png with a black alpha channel, & drop the TC generator in that. In the FCP browser, you can make that blank still to be as long as you want, FCP's slug can only be 2 minutes long.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
Patrice Freymond
on Oct 10, 2009 at 7:09:48 pm
Reviving this thread to say that there is another alternative:
1) Get the clock generator plugin for FCP from Matthias http://www.mattias.nu/plugins/, it is free but you can make a donation
2) Generate the countdown choosing style from your system's loaded fonts
3) export to use in Motion 3
N.B. As I haven't upgraded to fcs 3 I don't know if said plugin works in fcp 7
Also, as for every generator in fcp, slug included, you can make them the length you want by changing their duration in the viewer.
Hope this helps
Patrice
