Brain Freeze- Transitions in Motion??
COW Forums : Apple Motion
Noah Kadner
on Mar 31, 2008 at 5:49:40 pm
I want to do a dip to color dissolve between two stills in Motion. In FCP I just drop a dip to color transition between them and I'm done. What's the simplest way to do this in Motion?
-Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the HD Survival Guide!
http://www.callboxlive.com
Jim Johnson
Re: Brain Freeze- Transitions in Motion??
on Mar 31, 2008 at 7:24:57 pm
Howdy,
If I understand the dip-to-color correctly, you can just straddle your stills with a Color Solid generator that has a Fade In / Fade Out applied to it.
Noah Kadner
on Mar 31, 2008 at 8:34:04 pm
That worked like a box of Lucky Charms. Thank you sir. :)
-Noah
