Field Issue
COW Forums : Apple Motion
Colin McQuillan
Field Issue
on Mar 6, 2008 at 11:27:28 pm
Motion intermittently exports only single frame when exporting movie.
It's happened to me a few times using different export settings. IE: With and W/O motion blur and/or field render with Best selected.
I've also seen this on two different systems, mac pro 2x2.66 4gig, RadeonX1900, and also on a mac pro 2X3.2octo, 8gig, gforce 8800 GT
Is this common, or is there a setting I should be looking for, or export setting I should avoid?
I've had this affect entire exports, and also only portions of exports. Only a single field is exported (line of picture then line of black, then line of picture, then line on black..... so on)
Sequence setting is always Broadcast SD NTSC.
Colin McQuillan
Vancouver BC
Octo 3.2, 8gig, 8800GT, 2x23" ACD, 2TB G-Speed eS, Kona LHe....
MBP 2.4, 4gig , 2xLacie Quadra 500gig....
Colin McQuillan
Re: Field Issue
on Mar 7, 2008 at 2:09:59 am
[Colin McQuillan] "Motion intermittently exports only single frame when exporting movie. "
By frame I meant field
Colin McQuillan
Vancouver BC
