import illustrator files no sequence
COW Forums : Apple Motion
Saul Aldea
on Feb 14, 2008 at 1:32:37 pm
I have trouble importing illustrator files to motion, it always import them as sequence even if "image sequence" check box is not checked.
Im triying to import several layers exported from illustrator as illustrator files pdf compatible. But motion only sees them as sequence.
The image is a segmented logo, so if I change the name for no sequence name it will be confusing to work with.
What can I do?
Thank you.
Noah Kadner
Re: import illustrator files no sequence
on Feb 14, 2008 at 5:53:50 pm
I'd switch it to a PSD in Photoshop first, Motion is not number one with Illustrator files.
Noah
Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the HD Survival Guide!
http://www.callboxlive.com
saul aldea
on Feb 15, 2008 at 12:06:23 am
Ive found a way, renaming with a rename aplication the layer numbers to letters, that way motion doesnt detect it as pdf sequence.
cheers.
