Exporting lower field footage
COW Forums : Apple Motion
chris hayward
on Jan 27, 2008 at 2:41:04 pm
Hi. I work mainly with PAL projects and most PAL DV is set to a default of lower field. When I export from Motion, even though I have it set to PAL settings, the exports always come out as upper field - I test it by dragging the clip into Final Cut and checking the item properties - always says upper field.
I usually choose the lossless alpha codec when I export from motion but again, this always winds up being upper field. So what export option should I be selecting for the footage to look great AND be lower field.
Chris
