HDV footage is being squeezed. Help!
COW Forums : Apple Motion
Brian Pitt
on Jan 14, 2008 at 7:02:58 pm
Everytime I import any HD footag into Motion, it gives it a horizontal squeeze so that it becomes 4:3. Is there a simple something I need to do to fix this? My project is set at HDV1080i. that is the same as the footage I'm importing.
Brian
tim schultz
Re: HDV footage is being squeezed. Help!
on Jan 15, 2008 at 10:20:32 am
If you need to see your Footage in the correct aspect ratio
go to the View Options in the Right Hand Corner and toggle the "Correct for Aspect Ratio" menu item
This should adjust the aspect Ratio for the Footage
Brian Pitt
on Jan 16, 2008 at 4:51:16 pm
Thanks! I'll give this a try. I've never worked with 16:9 footage in motion...
Brian
Robert Grove
on Jan 15, 2008 at 12:09:38 pm
Hi there,
Have you checked if "Correct for Aspect Ratio" is on ?
It must be on!
Hope that helps :)
