Rotating a layer
COW Forums : Apple Motion
Brock Masterson
Rotating a layer
on Jan 9, 2008 at 11:58:17 pm
How can I rotate a layer?
I created a fly flying around a motion path and duplicated it 9 times. Now I want to rotate the layers so the 10 flies don't appear to be chasing each other.
I know I could have used particles to simulate multiple flies but I need each fly selectable for a DVDSP menu.
The only way I can think would be to export each layer separately and rotate them in FCP, but I'm having problems with this workaround as well.
Brock
david bogie
Re: Rotating a layer
on Jan 10, 2008 at 10:11:48 pm
Can't tell form your post:
Are the flies on separate layers or groups?
You can easily set behaviors or randomize parameters to the individual flies. This assumes your anchro oint is in the center of the fly.
Try disabling all but one while you experiment.
The use of an emitter to create the nine bugs would be a good thing to learn. I'm not sure how you're going to make moving object selectable as buttons in DVDSP, though. Let us know how that works out.
bogiesan
This is my standard sigfile so do not take it personally: "For crying out loud, read the freakin' manual."
