plugins folder path
COW Forums : Apple Motion
Mark Palmos
plugins folder path
on Dec 2, 2007 at 7:05:59 pm
Hi there
I have been testing some fxplugs, and AFAIK they should be put into /Library/Plug-ins/FxPlug for Motion to see them... but that does not work - or the plugins do not work...
They work in FCP and for FCP ive put them in
/Library/Application Support/Final Cut Pro System Support/Plugins
Anything I might be doing wrong, or are some FXPlug FX compatible with FCP only?
Niclas Bahn
Re: plugins folder path
on Dec 19, 2007 at 8:47:28 am
AFAIK most FxPlug plug-ins come with an installer that you have to run to install the plug-ins.
FxPlug is compatible with both Motion and FCP, but Motion does not support FxPlug transitions.
All the best,
© 2018 All Rights Reserved
