Bar chart movement
COW Forums : Apple Motion
pprince
Bar chart movement
on Nov 29, 2007 at 6:05:22 pm
How would I create a bar chart that would move from 0% to its data point? For instance, if the bar is 35%, it would move from 0 to 35 in Motion 3. Thank you
Kevin Hamm
Re: Bar chart movement
on Dec 7, 2007 at 7:42:36 am
you'd have to define your chart area, pick a frame to choose as the start point, click on the bar and set it's height (or width) to 0, and add a keyframe to that property, and then move the playhead in the timeline to where you want the full-growth of the bar to stop and change the height (or width) to be whatever value would line up with your chart area mark for 35.
I don't know of any way to generate this via a data table. If anyone else does, please let us both know.
