Film Burn Look
COW Forums : Apple Motion
Aaron Aphasia
Film Burn Look
on Nov 28, 2007 at 4:50:45 pm
Is there a way to build a film strip burn in Motion? I want to have an image freeze, then change to sepia and burn/melt as a transition. Just not sure how to go about it but it seems like it should be easy enough. Thanks for any advice, Aphasia
Noah Kadner
Re: Film Burn Look
on Nov 28, 2007 at 11:18:44 pm
I'd do a search for some tutorials. Also you can do much better and more realistic effects with stock footage- try:
http://www.istockphoto.com/index.php
http://www.artbeats.com/
-Noah
Unlock the secrets of the DVX100, Apple Color and now the HVX200!
http://www.callboxlive.com
Burt Hazard
Re: Film Burn Look
on Nov 29, 2007 at 2:02:05 pm
You could animate a rough ellipse mask shape and use animated color filters.
Aaron Aphasia
Re: Film Burn Look
on Nov 29, 2007 at 3:05:54 pm
THANKS!
Tim Burgess
Re: Film Burn Look
on Dec 29, 2007 at 12:02:17 am
I've done a paper burn animation - it may be of interest to you. It takes a displaced paper image (courtesy of Dave Nagel) and scales up the Corona emitter with a custom shape. I also use a copy of the shape with a radial gradient to produce a scorched outline before the flames. The project is at http://homepage.mac.com/timburgess/motion/Paper Burn.sit
Tim Burgess
Magnetic Island
