Can I convert shape from PS to path in Motion to animate on?
COW Forums : Apple Motion
Tangier Clarke
on Nov 7, 2007 at 5:35:24 pm
Folks, I made a stroke outline of the African country Tanzania in Photoshop. Is there a way I can make that outline a path in Motion 3, and then use a paint stroke to essentially draw that shape? If so, how would I go about doing this?
Thanks.
Tangier
specialcase
Re: Can I convert shape from PS to path in Motion to animate on?
on Nov 8, 2007 at 3:10:18 am
Howdy,
I just tried this out (in CS3, but it probably works in earlier versions) and if you save your PSD file containing your path, you can then open it in Illustrator and it still shows up as a regular path. Once you've got it in Illustrator, you can use the export script found here to convert it into a Motion shape preset, which is fully editable/animatable.
JeffG
on Nov 9, 2007 at 5:59:02 am
Yes.
Make sure the path is on a separate layer.
Take a basic brush + write on.
Paint the path.
Add an Image mask to the path layer.
Drag the basic brush to it.
Since the brush is painting on the alpha, it should paint the path on.
Best,
Jeff G
Principal Instructor
Future Media Concepts
FMCTraining.com
Editorsretreat.com
