How was this created?
COW Forums : Apple Motion
alexalex132
on Nov 4, 2007 at 1:37:37 am
How is this done?
Okay, I have the basic idea, I just need some help putting it together. I've cut out the "pieces" of a freeze frame from the footage I'm using. I just need help with putting it together in motion. Thanks.
-Alex
Ben Heusner
Re: How was this created?
on Nov 5, 2007 at 7:05:31 am
Should be a straightforward matter of having each cutout piece as a separate layer then transition these in as you see fit.
If you want an interesting wipe effect then Add a Layer Mask to each layer, set it to Luma. Then create an interesting gradient, and set this as the layer mask for your cutout layer (just drag and drop it into the image mask layer). Finally add a Brightness/Contrast filter (to your grad) and play away.
Lather rinse repeat for the other layers.
That should do it for you. There are, of course, other ways to achieve the same effect.
Cheers,
Ben
Curious Turtle Professional Video
Training | Editing |Support
http://www.curiousturtle.com
