frame blending in retiming "behavior" parameters
COW Forums : Apple Motion
Bob Roberts
on Sep 19, 2007 at 3:40:14 pm
When I look at a clip under INSPECTOR>PROPERTIES>TIMING, I get a certain set of adjustable parameters including the type of frame blending used in retiming.
If I use a retiming behavior, I don't get those same parameters under INSPECTOR>BEHAVIORS.
So my question is, if I use a retiming behavior, how can I define what type of frame blending method to use?
Thanks in advance.
specialcase
Re: frame blending in retiming "behavior" parameters
on Sep 19, 2007 at 11:07:31 pm
Howdy,
The retiming behaviors respect the blending mode set on the layer.
Bob Roberts
on Sep 20, 2007 at 2:55:38 pm
That's what I figured and I'm trying to find a way to work around that. The problem is that ultimately the frame blending (...in this case optical flow) actually "blurs" the area that I'm not retiming because, as you stated, it applies to the entire layer.
Any thoughts?
