Problems with batch export
COW Forums : Apple Motion
rob tobin
on Sep 10, 2007 at 8:39:18 pm
Hello,
After upgrading to Motion 3 I can't find a good way to "batch export" multiple files without getting corruption. There's the work flow. I build shells in After effects that has an alpha channel then I import to motion to create text for over a hundred of these "shells" to be imported to FCP6. With Motion 2 I would Export using Compressor... then build a custom preset and batch away. A slow process but it worked. Now when I try this compressor wants to put each file as a different batch and I have to hit submit for each... The other way is to make a droplet and import the motion projects which seems great but keeps messing up the renders
(a ghosting or studder problem) This is using the preset for Animation Alpha NTSC. I'm going to try Animation alpha without the NTSC to see if this works... Any ideas?
Rob
