Transparent bkg issues......
COW Forums : Apple Motion
hdfilmmaker
on Aug 29, 2007 at 6:32:05 pm
A transparent bkg will not import from Photoshop TIFF into motion. Motion adds a white bkg behind the shaped image in the TIFF. HELP please.............
stevec319
Re: Transparent bkg issues......
on Aug 29, 2007 at 10:10:06 pm
Make sure the background layer in Photoshop is transparent (has the grey and white checkerboard pattern on it), then when you save it as a tiff in the tiff options dialogue box that comes up click the check box next to Save Transparency. It'll give you a warning about other applications not supporting it, go ahead and save it and it will import in to Motion with a transparent background.
You can also bring PSD files in to Motion and it will keep all your layers as they were in Photoshop so you'll have a lot more flexibility.
Cheers.
hdfilmmaker
on Aug 29, 2007 at 10:57:27 pm
Thanks, we fixed the problem with psd. Cheers.
Is that the color red you want to use?
