Help! Imported Images are cropped
COW Forums : Apple Motion
sparkyflint
on Aug 23, 2007 at 9:35:54 pm
when I import image sequence into Motion they are being cropped and I can't figure out why.
The images are a .tif sequence and are 720x480, just like the project is.
I've checked all the settings under "media" and they seem to be right. The crop values are set to zero.
When I douuble-click the preview window in the Media tab, or "open in viewer" it generates a preview that shows the entire imagem, with the correct aspect ratio, and no cropping or stretching. However the preview window thumbnail even shows the image as being cropped and stretched.
HELP!
Noah Kadner
Re: Help! Imported Images are cropped
on Aug 24, 2007 at 12:04:04 am
What about the scale properties? Also make sure it's not in a layer that already has some cropping applied.
Noah
Unlock the secrets of the DVX100 and now Apple Color!
http://www.callboxlive.com
sparkyflint
on Aug 24, 2007 at 12:48:52 pm
I think I have figured it out.
I'm not sure why, but it seems that the ".tif" extension is causing it to crop and stretch the image. If I batch them through PhotoShop and change them to ".tiff" they go into Motion as expected.
a little buggy if you ask me.
