Text Masking Problem
COW Forums : Apple Motion
hunterlane
on Aug 16, 2007 at 7:41:37 pm
I've been working on a project that requires text masking. As far as I know, the mask tool does not work with text like it does with other objects. To solve this problem I used solid black rectangles to reveal the text (the background is also solid black). This works fine on my computer screen, however, the rectangles appear as subtle artifacts on my broadcast monitor. I've messed around with encoding and render settings, but I can't seem to get away from it. Is there any way I could prevent these rectangles from appearing in the final render? Or possibly use an alternative method for text masking (the right way)?
Thanks for the help!
Martin Baker
Re: Text Masking Problem
on Aug 16, 2007 at 8:48:48 pm
Add an Image Mask to the text object, create a new shape and drag it to the Image Mask source.
Martin
Digital Heaven, London UK
Unique plug-ins and tools for Apple Pro Apps
Avid2FCP
For Avid editors learning FCP
hunterlane
on Aug 16, 2007 at 10:50:40 pm
thanks a lot, I probably wasted 6 hours doing it the other way
