attributes
COW Forums : Apple Motion
Steve Kahn
attributes
on Jul 27, 2007 at 12:22:07 pm
Does motion have a "copy attributes" feature where any moves I create on one clip
I can apply to another?
Also, can we replace media as in fcp?
Many thanks,
Steve (loving Motion)
Dion
Re: attributes
by
on Jul 27, 2007 at 5:39:13 pm
If you are trying to just match the 2d movement of a layer, then you can use the match move behavior. It's basically a tracker but it works on animations built inside Motion as well.
as for the replacing media; yes you can.
There are a few ways. You can just drag and drop replace directly in the Layer List. Or you can right click over the clip in the canvas, sleect "Reveal Source Media" from the list and in the inspector on the media tab there is a button to "Replace Media"
dion
Don Smith
Re: attributes
on Oct 16, 2009 at 10:45:36 am
Easy. Look at the Inspector of the object you want to copy and simply drag whatever attribute you want to copy to any other object in the Layers window. For example, drag "Position" of one object and drop it onto another object.
Don Smith
NewsVideo.com
NewsVideo.com
